To have the Vintage Radio screen (see above) on the Front Panel, see Can RoseFM be made available on RS130?
Using Tital on RS130: https://youtu.be/XDhkdaG9A9U?si=fcuak0-VcfvVnNOU
Music Navigation via Front Panel : https://youtu.be/KqCqUlLUmfk?si=gNSTtTQFbAeOSqEe
Music Videos & HDMI Out: https://youtu.be/J9zyhjyuW7o?si=xLLn-jP0twhihX6s
Thanks @ROSEHAN for the following instructions (re: Why three radio apps? - #12 by ROSEHAN)
RS130ā>RoseRadioā>Select the 3rd icon (My Radio) at the top leftā>Select the + icon at the top right
Thank you @alessandro for the following video example of the Rose Connect Premium app (re: "Rose Connect Premium" - #5 by alessandro)
To view music videos on the TV, you must turn on the TV by clicking on the switch that appears on the upper right corner of the screen:
For examples of the android RoseConnect Premium appās display screens, see RoseConnect Premium app vs RoseConnect Premium (Early) app <- Android Apps
Thanks to @ROSEHAN for showing us how to play an entire album (re: Simply Infuriating - #3 by ROSEHAN)
Hereās another one.
Whenever I add an album to a playlist, the previous album cover which was shown on the playlist is replaced by the latest added album cover.
Why?
How to use the File Manager; see video:
While at a friendās place, you can play RoseConnect music on your smart phone.
To do this:
Start the RoseConnect app, then go to the Device Management setting and register your smart phone device ā do this while you are near a HiFi Rose device.
After step #1 is done, you can be anywhere: start the RoseConnect app on your smart phone; then go to the Device Management setting, select your smart phone as your current device and then play RoseConnect music on your smart phone.
See:
Select the āsettings cogā in the upper left corner of the specific port group of interest.
The following will then appear:
Proceed to change the desired checkmarked portsā characteristics
Resampling in the RS130 is not recommended, unless it is for compatibility.
Thank you @dtp for the following (re: Some feature requests - #2 by dtp)
joyofmmvid,
Great information about activating VU meter via the remote. Is there a similar set of remote commands to deactivate the VU meters? I find that at times when Iām trying to get to the main music playing screen, that the VU meters will appear instead. It would be great if there exists a remote command to remove the VU meter display.
For Support/Tutorial Videos, go to
